i have two problems one if i drive my car for say 10 miles it starts to miss at low rpm like when you first leave a red light it gets pretty bad till you get above 2000 rpm then it runs ok also the trans is 3 months old when you first get in it it will shift fine but after you stop it will not shift right its like first and od arent there but if you let it sit for a while it will shift fine again till you stop same with the missing if you let it sit for awhile it will run fine for awhile any help would be great thanks
yea the trans is under war but the guy was being a jerk and said its the way i drive that i tore it up again so my lawyer will bring the car to him monday the guy swore up and down i had nos on the car it is bone stock aside from a flow master and k/n filter but not for long thanks again
