I am looking for a place to buy a keyed crankshaft hub for a 1995 lt1 trans am .The only place i have found that has them is thunder racing but they are on back order there .I was wondering if anyone knew another source to buy one.
keyed crankshaft hub for 95 lt1
95 trans am, golen engine 383 ,140k,6spd, procharger 12psi supercharger,racetronix fuel pump, 58mm BBK throttlebody,hooker long tubes,crane HI6-DSR ignition box,crane ps-92 ignition coil ,true duals, 60lb injectors,3.73 GM gears,csr electric water pump,edelbrock strut tower brace,descreened maf,ls1 aluminum drive shaft,centerforce clutch,accel extreme heat wires,lt4 knock sensor,autolite 104s ,hurst short throw shifter,8-01-05- 02 frt end and taillights,ws6 rims,shiny black paint job!!.Tags: None
Many years ago, CNC Cylinder Heads in Pinellas Park, FL used to key the stock LT1 hubs. Might want to check with them and see if they still do it.
http://cncheads.com/Fred
