After 45K Miles, my water pump is once again leaking coolant from the pressure release hole on the bottom. But must the Whole Water pump be replaced to fix this problem? What other alternatives do I have? Is witching over to an Electric Water pump an alternative? Would an Electric Water pump outlast the original water pump?
Another One Bites The Dust......
Several problems with electric conversions. They flow a specific output regardless of engine RPM.... not the ticket for extended higher RPMs. Increased load on the electrical system and if it quits, you most often don't realize it until too late. Some guys have wired in an idiot light that lets them know if the pump is on or off. That works if you notice the light.
In general, they don't last as long as a mechanical pump in daily driving conditions. They do free up a few crank HP, but some is given right back by the load on the alternator. For a race car, go electric. If you are mainly a street commuter, stay with stock. Just my .02¢
Thanks Joe!
So I absolutely have to replace the entire pump? I cant buy the seal/bearings and "Rebuild it?"1996 Arctic White Z28, A4, K&N CAI, TByrne MAF ends, BBK Twin-52mm TB, TB Bypass, SLP 1 3/4" Shorties, Richmond 3.42's, Dynomax Bullet Muffler W/Turn Down, BMR Adj. Panhard, EIBACH Pro-Kit, AFS ZR1 Wheels W/17x11" out back!
Thanks Guys!
Yeah, I figured if Im taking the water pump off, I might as well change the opti (85 K Miles). And if the opti's off, I might as well swap the cam for a Hot Cam Kit right?
Im going to take Joes advice and replace it with an original one. Thanks Again.......
And while your at it...
if you are going to do the cam, might as well pull the whole engine. Put in a 4-bolt 396, add forged internals...ooo, ooo, lower the compression so the 18# of boost coming from the ATI is happy... uh, wait, sorry....got ahead of myself. (HEHE)
Al 96 Ram Air T/A
I've been using rebuilt pumps with the lifetime warranty, the first ones about $75, and they last about 65k miles.
I also drill the weep hole to 3/16" and install a hose 90 deg. elbow, then connect a couple of feet of 3/16" hose and route it to a spot off the steering rack..... when it starts to leak the coolant comes out the hose to a noticeable spot, and not on top of the opti.The Old Guy! '94 z-28, m-6, t-tops, go-fast red, 316k. Now with '96 engine w/ Lt-4 hot cam, roller rockers, heavy duty timing chain, and Spec stage 2 clutch.
18# of Boost? LOL!
I think Ill stick to the Hot Cam Kit for now. LOL. Thanks for the Info Guys! Im gonna go with a Lifetime Warranty Pump, its much cheaper than from the Dealer, plus it comes with a Warranty! And I was thinking about doing something like that Weep Hole Mod that you guys are talking about, so Im glad you guys straightened that out. Wish me luck! LOL!1996 Arctic White Z28, A4, K&N CAI, TByrne MAF ends, BBK Twin-52mm TB, TB Bypass, SLP 1 3/4" Shorties, Richmond 3.42's, Dynomax Bullet Muffler W/Turn Down, BMR Adj. Panhard, EIBACH Pro-Kit, AFS ZR1 Wheels W/17x11" out back!
