Ok... here is the deal... I went drag racing on saturday, and ran my stock 140,000 mile LT1 to red line on everyshift.... so problems my first pass, but my second pass was a diff issue. 1st gear wnt great, grabbed second with no problem, ran it to red, then when grabbing for third, I found first again... the car bucked violently, and I stomped the clutch back in.... i actually shook one of my filter elements loose from my CAI on the track. Car drove fine, and I babied it home.... I have a dual centerforce clutch in it and a 410 posi 10bolt with TA girdle... Car seemed fine all the way home, All 6 gears went in and out pefectly, and the clutch feels ok..... Wondering if anyone had any insight on what problems I may be looking at down the road from that incident, any help or past similar experiences would be greatly appreciated.... THANKYOU....
What could I have possibly damaged????
When you shift into 1st from 2nd, you increase RPM by almost 50%. Shifting at 5,800RPM in 2nd puts you at 8,670RPM in 1st. Letting the clutch out caused a giant engine brake, and its not likely you reached that high an RPM. Most likely damage could be the pushrods, and other components in the valve train.
I managed to do it more than once, and never had a problem.Fred
Originally posted by popo8Ok... thanks. But is it likely I hurt the clitch or trans???? Motor still sounds great... is that a good indicator, she is still OK???? or am I due for trouble???
Go out and do a smokey burnout as penance..
seriously - you're most likely fine. No worries.99 SS, MTI Lid, 3.90 gears, Hurst shifter, DMH 3" e-cutout
