2000 Z28. The left turn signal works properly. The right TS doesn't make the clicking noise--doesn't flash. When I turn the right TS on the rear TS light comes on but doesn't flash. The front doesn't come on. No burned out bulbs. No blown fuses. Any ideas on where to look for the problem will be appreciated. Thanks.
Help with Turn Signal Problem Please
MouthcardTags: None
Try replacing the front TS light, even though it doesn't look blown.
There may still be a problem with the bulb, because what you are describing sounds just like what happens when the bulb goes out.
Randy99 TA "RBLUTA" - NBM, M6, Whisper Lid, SLP Fan Switch, 160* Thermo, SLP LM, BMR STB & LCA's.
2nd that
All in favor say I.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Mouthcard -
You might already know this, but there are two bulbs per TS lense. Mine did the same thing as you described and it turned out to be one of the bulbs. I think it was the one closest to the fender. It's a pain in the rear to get to, but a cheap fix.
