Since my last smog, I've added SLP headers, Carsound cat, new EGR valve, new plugs/wires, Dynaspark opti, new timing set, lower gears and PCMforless tune.
Well, prior to those mods, my NO(PPM) reading was ~300 for 15 mph, and ~260 for 25 mph. Max allowable is 689/706. Well I just had another smog test and my NO(PPM) is now 1008 and 855. The numbers about tripled. I'm not quite sure why since my EGR is supposed to be new. One thing I do have is an exhaust leak on the driver's side header, causing the BLMs to go around 145/120. I also had slight leak also with my old manifolds though (last smog check)....so I'm not sure that this can cause the NO to triple.
So my question is, what should I look for? Do I need to repair that exhaust leak, and/or do I have a PCMforless tune that's causing it to fail? I already questioned them to make sure they didn't delete my EGR system, but I'm a
to hear a response. Is there a way I can test my EGR system, physcially or scan?
HC and CO are fine.
EDIT Here's the chart
Thanks for any advice.
to hear a response. Is there a way I can test my EGR system, physcially or scan?HC and CO are fine.
