Sony Cd Installation
  • Sony Cd Installation
    Hi guys,im upgrading my stereo to a sony cd player,but obviously,its thinner than the standard pontiac unit,is there a new fascia trim to buy,so it fits in correctly,if so,where do i get them from?
    Im in the UK,
    1996 TRANS AM.
    Thanks in advance!
    Try Crutchfields www.crutchfield.com
      you can get them anywhere a local stereo shop, best buy, even walmart usually sells them.
      '95 T/A Conv., Green, Tan Top
      '00 T/A Silver
      '86 Chevy RCSB 4WD (LS1 to go in)
        i m pretty much sure you can find one at halfords, double din to single din size, and you might need to put something underneath , a piece of plastic or something
        Did you figure out where the wires go, if not i recently put a pioneer in my formula and i wrote down the connections
        93 t/a A4 3.23s
        99 Alfa Romeo 166 3.0 v6, red
        97 3.8 v6 A4 camaro, hardtop
        00 audi a6 4.2 40 valve v8
          Thanks guys,whats the correct word for these things?Adaptor plates,fascia plates etc?
          Havent got as far as removing the old one yet,but ill be in touch if i have any problems
            they're call din kits. that's what ive always called them.
              You will need;
              http://www.crutchfield.com/S-GKdf9MC...00&I=120993009
              and
              http://www.crutchfield.com/S-GKdf9MC...sp?I=120701858
              and
              http://www.crutchfield.com/S-GKdf9MC...sp?I=12040GM10
                If you want the advice of a 15 year experienced 12 volt installer, buy a Metra kit. They make the nicest kits on the market and they hold up well. That's all I use in the cars I've installed in and in the cars I own.
                  Here's what mine looks like using the DIN kit from Crutchfield.
