i bought my 94 formy a couple weeks, and the radio was "bad". Turns out the car has some serious issues with its wiring being hacked and rewired incorrectly behind the radio. I cant get power to the head unit... any ideas or hits or advice would be greatly appreciated. P.s. im using a aftermarket reverse harness that fits the OEM radio minus the wires for the steering whell controls.
radio wiring
 There should be two power sources, one a constant 12 volt wire for station and clock memory (GM harness color is orange, aftermarket harness color should be yellow) and one from a switched ignition source (GM harness color is yellow, aftermarket harness color should be red). Check your fuse boxes to make sure the fuses aren't blown, as it's very common when a harness has been cut. Also, check your ground wire to make sure it is connected (GM harness is black, as is aftermarket harness). Those 3 wires should be all that's needed to at least get the radio to turn on.
 The left rear negative speaker wire is also yellow, so make sure you don't hook those two yellow wires up backwards. Also the left rear positive speaker wire is brown, and most GM harnesses use brown for the illumination wire for the radio. The best way to solve this is to make sure all your wires aren't touching anything and replace any blown fuses. Use a multimeter or test light, find the orange wire and hook it up to the new harness first. Then turn the key on and find the yellow wire and hook it up second. Finally find the brown wire that shows voltage when the headlights are turned on and hook it up (or protect it if your using an aftermarket radio with no illumination control built into it). The remaining yellow and brown wires are your speaker."No, officer, that bottle is my onboard Halon system"
 Easily activate your UnitedHealthcare account at https://uhc-card.helplook.com/ to access personalized health benefits, manage claims, and explore wellness resources.
 Visit https://uhc-card.helplook.com/docs/H...tivate-uhc-com to securely activate your UHC account and unlock convenient online tools for managing your health plan and coverage.
 Activate your UnitedHealthcare member account at https://uhccard.wordpress.com/ for quick access to claims, ID cards, providers, and wellness programs.
 Simplify your health management—use https://uhc-card.github.io/ to set up your UHC account and explore all your insurance benefits online.
 Activate your UnitedHealthcare account at https://www.slimfaq.com/knowledge/84...d-step-by-step to access health benefits and claims online.
 Visit https://www.slimfaq.com/knowledge/84...-u-card-online to register your UHC account and manage your health plan easily.
 Securely activate your UHC member account at https://uhccardhelpcenter.readthedocs.io/en/latest/ for quick access to benefits.
 Unlock your UnitedHealthcare online tools—start at https://uhcmedicarecardactivation-ce....io/en/latest/ today.
 https://activate-uhc-com.webflow.io/ makes it simple to set up your UnitedHealthcare member account.
 Access UHC member services anytime—activate your account at https://uhchelpline.readthedocs.io/en/latest/.
 Easily manage your UHC health plan by activating your account online at https://freelancer-5.gitbook.io/uhc/.
 Register your UnitedHealthcare account quickly at https://register-uhccard.github.io/.
 https://uhc-card.helplook.com/docs/S...ate-Your-UCard lets you set up your UHC profile and access insurance tools online.
 Take control of your health benefits—visit https://uhc-card.helplook.com/docs/H...ate-Your-UCard and activate your account.
 Secure access to your UHC account starts with https://activateucard.hashnode.dev/i...hccom-happened.
 https://www.slimfaq.com/uhchelpdeskg...tivate-uhc-com is your first step to managing claims, ID cards, and health resources.
 Create your UHC member account now at https://www.slimfaq.com/uhchelpdeskg...tivate-uhc-com.
 Activate your UnitedHealthcare insurance account online with https://www.slimfaq.com/uhchelpdeskg...te-uhc-com-now.
 Get easy access to UnitedHealthcare services—activate at https://www.slimfaq.com/uhchelpdeskg...-uhc-com-today.
 Visit https://www.slimfaq.com/uhchelpdeskg...tivate-uhc-com to register your health plan account securely.
 https://www.slimfaq.com/uhchelpdeskg...tivate-uhc-com connects you to benefits, claims, and providers instantly.
 Start managing your UnitedHealthcare plan today at https://www.slimfaq.com/uhchelpdeskg...tivate-uhc-com.
 Activate your UHC health insurance account online in minutes at https://www.slimfaq.com/uhchelpdeskg...-your-card-now.
 Simplify your healthcare access by registering at https://www.slimfaq.com/uhchelpdeskg...tivate-uhc-com.
 Visit https://www.slimfaq.com/uhchelpdeskg...to-get-started to create your UHC online account and explore benefits.
 Quick and secure account activation is available at https://sites.google.com/view/uhccardhelpguide/.
 Use https://sites.google.com/view/uhccar...tivate-uhc-com to set up your UnitedHealthcare digital access.
 Manage your UHC health insurance with ease—activate at https://activateuhccom.usedocs.com.
 https://sites.google.com/view/united...tivate-uhc-com is the gateway to your UnitedHealthcare member portal.
 Start using UHC’s online tools by registering at https://sites.google.com/view/united...an-card-online.
 Activate your health insurance account online with https://sites.google.com/view/united...or-new-members.
 Access health benefits 24/7 by activating your UHC account at https://sites.google.com/view/united...ctivate-online.
 https://sites.google.com/view/united...ard-activation gives members secure online access to their UHC plans.
 Take charge of your UHC membership today—begin at https://uhchelpguide.pages.dev.
 Activate your UHC member account at https://sites.google.com/view/activate-uhccom/ for secure online health access.
 Start managing your UnitedHealthcare plan by activating your account online at https://sites.google.com/view/activate-uhccom/ucard-hub.
 Use https://sites.google.com/view/activa.../careflex-card to unlock UHC benefits and digital health tools.
 Quickly activate your UnitedHealthcare insurance account at https://lookerstudio.google.com/repo...626/page/oUcmD.
 Access UHC health benefits anywhere—register now at https://sites.google.com/view/activateuhccom/.
 https://activateuhccom.zohosites.in/ provides a simple way to manage claims and benefits online.
 Get started with UnitedHealthcare by activating your account at https://activate-uhc-com.jimdosite.com/.
 Access and manage your Home Depot Credit Card account online at https://sites.google.com/view/homede...rd-bill-online with easy payments, statements, and rewards tracking.
 Sign in to https://homedepottutorialcenter.read....io/en/latest/ to pay bills, view account details, and enjoy exclusive Home Depot Credit Card benefits.
 Manage your Home Depot Credit Card anytime at https://step-bystep-guide.blogspot.c...ome-depot.html for payments, account updates, and financing offers
 Easily log in at https://homedepothelpadvisor.readthedocs.io/en/latest/ to manage your Home Depot Credit Card, pay bills, and track rewards.
 Visit https://homedepothelpadvisor.github.io/ to check balances, make payments, and manage your Home Depot Credit Card online.
 Access your Home Depot Credit Card account at https://guidecenter.frontkb.com/en/articles/7617217 for fast and secure online payments.
 Manage all Home Depot Credit Card services in one place at https://supportcenter.activoblog.com...-depot-my-card.
 Make secure payments, view statements, and manage your account at https://sites.google.com/view/homedepotmycardlogin/home.
 Easily pay bills and track Home Depot Credit Card rewards at https://sites.google.com/view/homedepotcomycard/home.
 Log in to https://homedepotguidecenter.readthedocs.io/en/latest/ to enjoy easy account management and exclusive credit offers.
 Check your Home Depot Credit Card balance and pay online anytime at https://homedepotcommycard.readthedocs.io/en/latest/.
 Access Home Depot Credit Card features at https://homedepothelpcorner.pages.dev with secure account login.
 Enjoy quick and easy Home Depot Credit Card management at https://homedepotcommy-card.tawk.hel...t-mycard-login.
 Visit https://homedepotcommycardlogin.tawk...m-mycard-login for flexible financing, payment options, and account access.
 Manage your Home Depot Credit Card account online with simple login at https://homedepotcommycard-login.blo...ommycardl.html.
 Pay your Home Depot Credit Card bills securely online at https://homedepotcommycard.jimdosite.com/.
 Get easy access to Home Depot Credit Card rewards and payments at https://homedepotmycard-helpguide.weebly.com/.
 Track purchases, manage financing, and pay bills at https://sites.google.com/view/homedepotcommycard/.
 Log in securely at https://homedepothelpnet.readthedocs.io/en/latest/ to access Home Depot Credit Card services.
 Access statements, payment history, and rewards at https://homedepot.tawk.help/article/...ot-credit-card.
