Mobil1 Extended 15000 miles?
  • Mobil1 Extended 15000 miles?
    Any reason I should use this instead of the regular Mobil1 Synthetic? Thanks.
    I wouldn't, cause you still have to change your oil filter every 3,000 miles anyway.
    2006 Saturn Ion Redline
    2003 Mits. Eclipse Spyder
      I don't intend on going 15000 miles between oil changes. In fact, I currently change my oil every 1000-2000 miles. Probably overkill, but I like to keep the engine clean.
      Also, is it normal for the oil to be brown when only putting 1000 miles on new oil? Thanks!
        I would say def. stick with the regular and save that 10 bucks...especially since you change it very often. But about the color of the oil, i don't know, you'll have to wait for one of the guru's to answer.(there's you que fred)
          well i'm definately not a guru. but i do know that yesit's completely normal for your engine oil to be brown even if you change it that often. if it was black then i'd say there was a problem. but brown.....no worries.
          '95 T/A Conv., Green, Tan Top
          '00 T/A Silver
          '86 Chevy RCSB 4WD (LS1 to go in)
            It's not the life of the oil you have to worry about, it's the contaminants that the oil picks up. Regular synthetic is supposedly good for 10K miles if you change the filter every 2K. Personally, I never go farther than 3K on any oil. I would just stay with regular Mobil One and frequent changes.
              Joe hit it on the head
              '00 T/A Silver
                Joe's right. Simply change your oil every 3K and you wont have problems. As my father always said, "If its not broken, dont fix it."
                Eddie
                2000 M6 Trans Am
                Tune+exhaust=344WHP
                  This should be ok. I have seen some people that put even less than 1000 miles on the new oil and its brown. And I used to do 25+ oil changes a day!! When I was a Lube Tech. for GM.
                  Eddie
                  2000 M6 Trans Am
                  Tune+exhaust=344WHP
                    Regular Mobil1 with Lucas synthetic stablizer and Mobil filter since day on every 3000-4000 miles...229K on the clock with absolutely no problems.
                    I put in 4 quarts of oil and one quart of Lucas...I get back 4 quarts.
                      Is it just me or do the LS1's take 6 quarts?
                      Eddie
                      2000 M6 Trans Am
                      Tune+exhaust=344WHP
                        I put in 5 total and check the dip stick...it's right on. I've always put in 5 quarts...should I be putting in 6 quarts? I read 5.5 is what is recommended, but buying an extra quart only to put half doesn't add up for me...5 quarts and she's right on...I just might do 6 quarts then.
                          Do you fill the filter with oil before you put it on? Do you check the level AFTER allowing the oil to circulate and warm up? That will determine the exact fill quantity.
                          If you change the oil evry 1,000 miles, you aren't gaining any advantage at all with synthetic oil. The main benefit of synthetic is longer life, including maintaining viscosity stability for a longer period, and resisting coking at very high temperatures. These are not issues for a 1,000 mile oil change.
                            ls1's require 5.5 quarts of oil......
                            you can drink the other .5..... synthetic oil is good for you....
                            1994 formula A4 w/ 84,XXX MI, bone stock except MSD wires and NGK TR5 plugs
                              Of course I fill the filter before installing. Also, I thought synthetic was slippier than regular oil thus reducing engine wear. Anyway, I'll stick with regular Mobil1 synthetic.
