how do you remove the crank pulley hub? I've seen some with 3 holes in it but mine doesn't have any..
removing the cranks pulley hub..
Does it not look like this one from Shoebox's photos:
If not, its not a stock hub. How did you get the damper off the hub? Did it not have three bolts holding it on the hub?
And does your hub not have three threaded holes in it, exactly like the top photo of the two above?Originally posted by Atl_Monteyup looks like that one
I'm still not sure I understand what you are asking.Fred
Clarification is needed. Are you removing the crank pulley or the hub? The hubs pretty much look the same, so I would guess you need to remove the pulley. If it looks like the pulley above, wiggle it off or use a puller as shown. Later model pulleys have three, small holes between the spokes, so a regular balancer puller can be used to remove it (both types seen in this diagram).Rob B 95Z A4 Tech Page (Part numbers / locations, how to's, schematics, DTC's...) Home Page - shbox.com
