So i took out my axles to change the berings and realized that one of the axles got chewed up, and i was wondering wares a good place to get one (1) axle as a stock replacment. Also theres a gear on the end of the axle that gets read by a sencor im guessing its the Abs or Trac control. Does that come with a new axle or do i have to somehow get that off?
axles
axles
1969 z28 - 9.957 @ 133.92 1.425 60 foot.Tags: None
There will only be a reluctor gear sensor on the end of the axle if your car is equipped with both ABS and TCS. If you have the gear on the end of the axle you have to get a replacement with an identical gear or swap it out. That's called a 4-channel system. They should be removable.
Any junk yard will have the axle, or you could go to someone like Moser to get a new one.Fred
