My driver side window has been acting up the past couple months. It will work fine for 2 weeks or so, then act up for a day. It will go down with no problem, but when going back up, it goes 3/4 of the way then stops. After it gets 3/4 of the way, the last 1/4 goes up in 1" increments about 5 mins. apart. Is this the motor going out? Also the little red light that lights up the buttons on the door goes on and off while I drive. I was playing with it and the two aren't related because with light on or off the window still doesn't go up. The light is just something else I would like to fix if I have the door apart. thanks fellas!!
Driver side window
Driver side window
1999 Ram Air Trans Am. M6
Thanks guys, now I have something to do this weekend YAY!!!!1999 Ram Air Trans Am. M6
I replaced the motor and it was great fun, the most fun I have had in a long time
For those of you who don't have, or in my case can't find a C-clamp in your garage, I stuffed 2 used Zaino applicators between the window and the door and they held the window in place perfectly. C- clamp would have be the right way to go, but I wanted to get it done.
Great! Ken can add this to his list of "1000 uses for Zaino"!Originally posted by LS1 TAFor those of you who don't have, or in my case can't find a C-clamp in your garage, I stuffed 2 used Zaino applicators between the window and the door and they held the window in place perfectly.
Joe K.
'11 BMW 328i
'10 Matrix S AWD
