Hey everyone,
I have noticed that my 91 RS has a fair amount of oversteer. The rear wheels let go way before the fronts even think about loosing traction. What are the possible causes of this? Is this just how F-Bodys handle? My setup includes:
Eibach Pro-Kit Springs
Polyurathane Bushings
Stock "RS" sway bars
KYB GR2 shocks/struts
Sub-Frame connectors
3-Point Strut Tower Brace
Spohn Rear Control Arms w/ relocation brackets
Kuhmo Ecsta 245/50-16's on all four corners
Now I recently added 36mm/24mm WS6 sway bars and upgraded the shocks/struts to Koni Adjustables. I havent had a chance to test the new setup, but I am hoping that these new additions have corrected the problem. If I find that I still have oversteer, what actions can I take to get the car more balanced? I would think that I need to loosen up the rear end or stiffen up the front. If I recall correctly, drifters use a really stiff rear with a soft front to get the car to oversteer. I would want to do the opposite. Correct?
I know my tires suck, but since all 4 tires are the same, I dont think that would cause oversteer? Would it? I would think it would just take traction away from all 4 corners.
How about my rear control arm relocation brackets? Are they possibly adding to the problem?
Thanks for the help,
Mark B
Mark B
That being said, throttle induced oversteer can bite the inexperienced driver that's why the factory engineers the suspension to push through a corner as slowing down will correct the line and tuck the nose in. If oversteer was engineered in by the factory, too many people would kick the tail out by backing off the throttle and there would be serious problems for the unsuspecting and inexperienced. It really is a delicate balence.
