I've been trying to track this down. Maybe some of you can see if I'm on the right track.
I had a new LS7 clutch/pressure plate and new slave cylinder installed in November. I've been running a poly trans mount for about a year now. Where I drive I usually don't get up to 65mph, but over the holidays I noticed a significant amount of vibration. I did some testing and it looks mostly speed dependent. It maxes out at about 67mph in 6th gear at around 1,500 RPM.
I took the car out on the highway today to try to eliminate some possibilities. I accelerated up to 85mph in 5th and 6th. I checked 1st through 5th through 1,500 RPM at different speeds. The vibration seems has a moderate frequency...I'm guessing at least 25 Hz.
I had my tires balanced last week. That didn't help, so I went back to have the shop double check them. The vibration remains. I've had the poly mount on a while, so I'm used to what that feels like. This vibration is similar, but seems more pronounced.
So, here's what I'm thinking. It's not the clutch/pressure plate as it occurs only at a particular speed and not rpm. Maybe the shop had to disconnect the driveshaft to get at the slave cylinder and didn't install it in the same position as it was removed. Or, maybe the pinion angle is off.
What do y'all think?
That would be my guess for the vibration.
