I posted a while back about my car NOT warming up. It would be about 20 degrees out, I'd drive 20 miles home from work and the car would not move up much past 160. I assumed the thermostat was stuck open. Well, now it's been the opposite the past few days. The car warms up and keeps climbing. Today the check gauges light came on and I had to pull over.
Is it common for a bad thermostat to stay stuck open, then somehow close and stay closed?
When it was staying cool, the fans weren't running constantly or anything.
I noticed today when I popped the hood, I could hear a fan, and feel air, but the two fans that you can see behind the radiator weren't running. That can't be normal.
I'm going to swap the thermostat friday to see if that helps. What else should I look at? Is there a sensor that tells the fans when to turn on that isn't working properly? Which fan was running when I shut the car off?
