Just curious if anyone on here has installed a 454 in a 3rd Gen? I was given an early 70's 454 4 bolt main engine in a trade for some work. I have a 1985 Z28 that currently has a 1970 Vette 350. I'm assuming swapping to a 454 will require some suspension upgrading. Also, my car currently has a 700r4 trans which will be changed to a turbo 400 more than likely if I go through with the swap. Thanks in advance for all info and advice.
454 in 3rd Gen Camaro
its been done. www.thirdgen.org will have the info u need if ur search for it. i almost bout one. it was a 88 iroc with a 70 ss chevelle LS6 454 with a t-5(its headed for a early death). not much room thats for sure.2009 Honda Civic EX- the daily beater
Thanks for the info. There's definitely not a bunch of room under the hood for a 454. I was actually planning on turning my 350 into a 383 stroker when I was offered this 454. I need to run the numbers on the block and heads to see exactly what I have. I'm also concerned about my 9 bolt rear end holding up to the higher torque output of the 454. Thanks again for the info.
9 bolt will break if u hook up decent over time. i got a webpage so u can look up the numbers. let me find it for you real quick
edit: here it is http://www.mortec.com/2009 Honda Civic EX- the daily beater
high 12s are done with LS1 cars, so u could see 11 seconds if its done right and nothing breaks. but word of warning, the 9 bolt isnt that much stronger then a 10 bolt2009 Honda Civic EX- the daily beater
