Will they fit on a 97 z28 LT1? Any major differences? I'm picking up a spare set and one happens to come off a 94 vette.
94 Corvette LT1 heads..
Tags: None
They will be a direct bolt on perfect fit.Tracy
Thanks Tracy! I've beenOriginally posted by TraceZThey will be a direct bolt on perfect fit.
on an answer to get them.
When you put the "early" LT1 heads next the "late" LT1 heads, you're going to be surprised at how much different they are. They are fully interchangeable, and direct bolt-on, but GM changed the outside dimensions a bit, and thinned out the wall thickness in the later heads. There a thread on the LT1/LT4 Engine Tech forum, on CamaroZ28.com showing the differences in appearance.
http://64.65.63.61/forums/showthread.php?t=427346Fred
very interesting. If I had only looked at pic's of the heads I'd have assumed they weren't compatible at all.97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
