Do the 3800 V6's have issues with oil consumption? Has anyone here had a problem? What is normal? My engine does have almost 100k miles but still, a lot of people have much more than that.
I think I may have a problem. My engine used to never be low. Yesterday I discovered that I was a qt low - 4,000 miles & 5 months after changing the oil - however, I may have added a little bit after that but I forgot to record it. I do not have any visible leaks on the ground or on the engine except for light seepage which is normal - in fact, its been about 4 months since I washed the engine and the tight spots around the edges of the valve covers is still clean. Last time I was under the car in the fall, all the gaskets were clean. I think i may be burning oil?
The consumption has definitely increased. i was reading that LS1's have this problem but i have not read anything about the V6. I've also read that GM service people say that 1qt/3000 miles is normal. How do you test an engine for burning oil?
Bruce
Bruce
