Anyone have experience with these? Since the broken header bolt and constantly running rich, I finally decided that a head swap is coming soon.
My goals is simply to swap the new heads in, and keep the stock components. So they'd be with the stock cam, pistons, etc. I already have CC 1.6 RRs and valvetrain. In the future, when time for a rebuild, I'd definitely clean up the AI heads and use them again, along with a better cam (but it must be CA smog-II legal).
I already contacted AI, and they recommend that I get the fully ported 200 cc heads, since I'm going to use them in the future, after a rebuild. However, they really didn't tell me if it will hurt anything for now, with a stock cam. And I didn't hear if they would hurt in smog tests, versus the 185 cc heads. I'm sure that any set will be better than the current ones, that leak at the header/head flange. Also, the price difference between all 3 packages aren't that much.
Do you think it's worth it to get the fully ported heads on an interally stock motor that has to pass smog? Thanks in advance for your advice.
