Timing chain was acting up.. getting noisy. Girl ran it with little oil. Found some plastic
in the chain on tear down. (thought it
was metal at first). Had originally thought
the chain broke.
Tested compression. I have 0 compression in every cylinder (95 saturn SOHC).
So I figure the chain jumped or something
funky. I tear it all apart. Didn't note
were the timing marks were, but when
I went to reassemble it today, after reading where the marks where for
timing, I noticed it was off. The right
plastic chain guide was missing and busted
off.
I replaced the chain, tensioner,
chain guide and sprockets and set
the timing correctly.
Still NO start. NO compression in #2.
(Didn't want to bother to test the otheres.).
I guess my question here, is that
without compression, there isn't
any chance of a cylinder firing?
It appears that no cylinders are firing..
I don't know if there has been valve
or piston damage. There is nothing
hitting (before) or now when I crank
it or rotate it.
I imagine the engine is toast with mechanical problems.
the chain broke.
off.
I replaced the chain, tensioner,chain guide and sprockets and set
it or rotate it.
for Saturn to release the Ion Redline with the supercharged ecotec. I'll probably end up going with the ecotec, since they're supposed to be capable of handling up to a 1000HP.
