syncro repair
  • syncro repair
    I messed up my 5th gear syncro and I took it to a shop for an estimate. They told me $680 labor and $500+ for parts. This does not seem right to me. I have read where there are shops online that will entirely rebuild a T56 for like $700. How hard is it to fix this problem by myself? Is a manual tranny more dificult than an engine rebuild?
    1999 Ram Air Trans Am. M6
    Wow that's high. That sounds more like a quote for a complete rebuild.
    I have used this place before for a T5. http://www.southerngearco.com/
    FYI the synchro is about $20. I bet that the gear would have to be pressed off to get to it (5th) though. On a T5 you can get 1-3 off without a press but 4th gear has to be pressed off to get to that synchro.
    BTW you can't really do anything to damage a synchro. The float around and are only used during shifting.
    Also BTW I just replaced my clutch assembly and what I thought was a bad synchro for 3rd gear has gone away. I don't think the clutch was releasing all the way. All the rest of the gears were fine.
      Thanks for the information and suggestions. I can shift from a lower gear to fifth, I just can't down shift into fifth. As time goes on, getting it into fifth gear is beoming harder. Does this sound familiar to anyone?
        The Only thing I have thats Kinda the same Is putting in Reverse that Im sure alot of you guys remember. Just been Trying to Deal with it. Sometimes it goes in okay if I go ahead and shift it into 2nd first then Reverse.
        Eddie
        2000 M6 Trans Am
        Tune+exhaust=344WHP
          If you'd like to see how difficult it is to disassemble the T56, and the special tools required, take a look at the T56 repair manual. Shoebox has it on his website:
          http://shbox.com/1/4th_gen_tech2.html#t56
