i have a stock camaro ioroc 89 tpi 5.0. i recently put in a custom programable performance chip stage 2. i have a underdrive pulley kit installed. i have not cat. on the car. i have a airfoil installed. i have a mac performance catback exhaust installed. i recently purchased edelbrock headers, SLP runners, K&N filter and a new blaster coil. these still have to be installed. i was thinking of purchasing new injectors. but i dont know what size? also, do i need a fuel pressure regulator or can i have the guy reflash my performance chip to accomodate the bigger injectors. will these injectors be a waste of money or will i see a noticeable gain in h.p. i was just thinking since im changing the intake runners i mine as well do the injectors. would i also have to purchase a bigger fuel pump or will the stock one be finesince my goal is only 300 hp. my goal is to reach the golden number of 300 hp.please help with any ideas to reach this. would 410 gears be to big? and i need to know what size of torque converter to go with. i'm up for any ideas? i got my income tax return and want to put it all in my camaro. please help
will bigger injectors help? and what size do i go with
4.10's seem a little to big. Maybe some 3.73. You can get like a 2500 stall Converter. I would not change the injectors, they are not so cheap. Get some Roller Rockers, They prove like 20 hp I think. THen Again thats for an LS1. There is not to much more you can do, but to go Internals. Some head work maybe. I dont know to much about the TPI engineEddie
2000 M6 Trans Am
Tune+exhaust=344WHP
its a auto 700r4Originally posted by ConEliteIs it Auto Or Manual? 4.1's seem a little to big. Maybe some 3.73. You can get like a 2500 stall Converter. I would not change the injectors, they are not so cheap. Get some Roller Rockers, They prove like 20 hp I think. THen Again thats for an LS1.
I've found you can approximate the injector requirements by multiplying the flywheel HP by 0.07. If you're talking about 300 flywheel HP, you'd be looking at a 21 #/HR injector (300 x 0.07 = 21). That assumes you have a moderately efficient tune (0.475 #/HR/HP BSFC) and don't push them over 85% duty cycle. I don't know what the stock injectors are on the 85 5.0 TPI.
The best approach is generally to keep the fuel pressure at the stock setting, and have the new injector flow constant and offsets programmed into your chip.Fred
