Turns out, my blown head gasket resutled in a seized motor. Time to bore out my backup block and go for a new rotating assembly.
Any suggestions for a limited budget? If I get all the machine work done should I try to build myself or have it done? I have built a ton of 2 stroke, and 2 successful LT1 top ends but never got into 4 stroke bottom ends. I am sick of working on this car, want to get something that will last. Any suggestions on good builders?
Do superchargers hold up to the cruelty of road-racing? Figured if I was going to build a motor, might as well look into low compression pistons and high boost. I know the mustang guys have not had good luck with this kind of sustained RPMS.
Any advice would be appreciated, very bummed about this, just when I thought I had this car straight again!
