Does anyone know of any kindof 15 inch rim i can fit onto my car, and what exactly rear spacing means, DOes it just mean how much the tire sticks over on the back side? because i bought a 15'x8 rim with 4.5 rear spacing and it hits the calipers, if i get a 15 x8 wuth a 5.5 rear spacing.. will that help at all or no?
Tires..
Tires..
1969 z28 - 9.957 @ 133.92 1.425 60 foot.Tags: None
Offset is how far from the centerline of the wheel the lug nut surface is
Backspacing is the dimension from the lug nut surface to the back of the rim.
When you say that the rim is hitting the calipers... Where is it hitting? Since you have a 2000 car, you have 12" brakes at all 4 corners. I think it may be hard to get 15" rims to fit right no matter what backspacing you get.No F-Body right now
There are 15" drag wheels that will fit. For the rear, you need 15x10" with a 7.5" backspace, or 15x8" with a 5.5" backspace. Any less backspace, and the wheel/tire will be outside the fender line. In general, its NOT the backspace that is causing the wheel to hit the calipers.... its the design of the center disc of the wheel.
For the Weld Pro-Stars and Draglites, the inner knuckle of the center disc will hit the brake caliper fins on the rear LT1 brakes, and probably similar on the rear LS1 brake. The cure is to grind the fins off the caliper on the LT1. I suspect there is a similar requirement on an LS1.
Bogart will make you a 15x9.5" wide wheel that fits perfectly, without spacers or grinding anything, on all years of the 4th Gen. But now you are talking about wheels that are $350 each, and not good for street use - only track use.
Centerline makes the Telstar in a 15x8" 5.5" backspace specifically for the 4th Gens, and I understand that there is no interference of any kind. The Telstar isn't as light weight as the Pro-Star or Draglites. I've also seen the Centerline AutoDrag mounted on LS1 4th Gens with no problems.
In the front, some 15" wheels like the Pro-Stars will hit the spring clip on the brake pads, or the horizontal portion of the steering knuckle. For the front, the solution is typically to use a 5/16" spacer. You will need longer wheel studs.
I have a writeup on the Welds and the Bogarts on the "Wheels and Tires" forum, FAQ stickied at the top of the forum page, and CamaroZ28.com, with photos of the mods.
http://web.camaross.com/forums/Fred
I looked at my breaks, and the "fins" that your talking about face inward, as in, there not on the outside which that little lip on the dragstars hit.[COLOR=Navy]2000 Navy Blue Trans Am, T Tops, Automatic, Ram Air, Slp 85mm Mas, Air Lid, Smooth bellow, Hooker 1.75 Lt's, ORY, LM1, Air/EGR delete, Throttle body coolant bypass. Msd super conductor wires. TSP cam, ss3600, svo 38LB injectors.
Its not fins on top of the caliper that hit, its the fins that wrap around to the side of the caliper, right on the corner. This is what mine looked like after I ground off the ones that interfered:
yhea mine dont look like that. Ill send a pic.[COLOR=Navy]2000 Navy Blue Trans Am, T Tops, Automatic, Ram Air, Slp 85mm Mas, Air Lid, Smooth bellow, Hooker 1.75 Lt's, ORY, LM1, Air/EGR delete, Throttle body coolant bypass. Msd super conductor wires. TSP cam, ss3600, svo 38LB injectors.
