Grrrr...it finally went
  • Grrrr...it finally went
    Well, after almost 140k and 14 yrs., the Opti on the Z went I believe. I fired her up last week to go home from work and she ran for about 10 sec....and hasn't run since. I followed Rob's testing procedure and got nearly 12 VDC on the 2 inside pins, but barely 0.05 VAC on the outside pin when cranking. So, either the Opti is gone or the harness is bad.
    Is the harness for the Opti a seperate piece from the main PCM harness? Or is it all one piece? And how would I test it? Thanks guys.
    Steve
    87 GN - its just a 6... Mods
    140K . . . not bad for an opti.
    Darrin C
      Esp. non-vented
      Steve
        Oh . . .also, I don't know whether the opti harness is one piece or a separate piece.
        Does anyone have the answer ? ? ?
        Darrin C
          Anyone know? Or how to test the current harness?
          Steve
            After poking around on Shoebox's site, I found the other side of the connection, as seen here...
            Thanks Rob
            Steve
