ok now the light is always on and the car is missing....problem is cant take it anywhere cuz the car has to be inspected for warrentty. Im thinkin its the plugs or coil...i got till saturday to fix thats last day to get warrenty. I really am starting to not like this car.
OMG THINGS GETTING WORSE!!
I assume by the light being on that you are talking about the SES light. You are going to have to have it scanned, A lot of parts stores will do it for free now. When you get the code, come back here and post it and we can help then.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Re: OMG THINGS GETTING WORSE!!
By the way, you have 8 coils..... which one do you think it is?Fred
yesterday i call a local schevy dealership asking about extended warrenties...they said that scince that car just came off warrenty and had so little milage, that as long as it passes an inspection, they will warrenty it. I was an my way there and the car started acting up...no it is having trouble starting and u smell gas.2000 Camaro SS
Red on Dark Grey Leather,
6 spd, Bilstein Suspension,
Auburn Differential, Chrome ZR1 Wheels, SLP Performance Exhaust (not loudmouth........yet
Could be a hundred things, get it scanned and at least post the code and then we can help. All your going to get from us now is a list about 100 items long to check. Thats the beauty of OBDII96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
tabahr
I'd have to agree with injuneer. Until you get it scanned and have some codes to look at there is nothing anyone can do to help much. I do not believe your car is a lemon, and would encourage you to not get to upset about a few little problems. F-bods are not Hondas. They will not go 150K without ever breaking. That does not make them bad cars, it just means you need to be a bit more understanding and willing to work. The payback is worth it, in my opinion as a hobbyist.
Look at this in a posative light. This is a chance to learn about your car and bond with it. This is a good excuse to purchase a scan tool . This is not the last time your SES light will come on, you know.
When you get some codes out of your PCM post them.
dont type in all caps broh. against the rules here.
thanks.
