I'm about to purchase some black ZR1's for my formula...Im gonna buy 18x9.5(offset:56mm) with 245/40/18 tires for about $500 total.Will those tires look bad? and will they rub or anything like that let me know please
Wheels and tires
Good choice in wheel size, will fit correctly with that 56mm offset. Not a good choice on tires. While they are the correct diameter, they are on the narrow side for a 9.5" wide wheel. While most tire manufacturers will accept a wheel width of 8.0-9.5" on that size tire, they generally "measure" the tire on an 8.5" wide wheel. If you think about it, the overall width of a 9.5" wide wheel is closer to 10.5" when you include the flanges that retain the beads on the wheel, but the section width of a 245 tire is closer to 9.7". The tire is going to look "stretched" on the rim.
One advantage of such a narrow tire is that there's little chance it would rub on anything. On the other hand, a 275/35-18 or a 285/35-18 would fit the wheel better, look much more aggressive, and not rub on anything either.Fred
1994 Firebird Formula(auto)
