My Pro Start one died. Anyone recommend a good, reliable, long-lasting battery for our cars?
New battery
Optima Red Top...amazing capabilities to store electricity, hence reliable first start in the mornings or under gross events: one day my serpentine belt tore apart and I was able to drive the car 14 kms to the nearest Autozone and replace the tensioner and the belt.
PONTIAC
Firebird
2002-1996 V8 5.7L
Part# RED75/35 CCA 720 Model Optima
Group Size 75DTO
Best regards
dochidalgo
add:
for you next Euratica CD.....
97 A4 Pontiac Firebird Trans am with $everal mod$
Optima or A/C Delco battery. interstate is ok, altho my boss did get 18 years outta his last interstate but dont think that is very common, the only reason he changed it cuz the negative cable was so corroded2009 Honda Civic EX- the daily beater
My Optima Red Top lasted 6 months. The shop that does my work threw it in their battery graveyard, which was mostly Red Tops. They recommended the AC/Delco Professional. I still have that one almost 7 years later, and its been very reliable, going months between starts of the car. I have used a Battery Tender most of that time, to insure that the battery was maintained at the correct state of charge.
Before buying the Optima, at least read the FAQ on their website, so you really understand exactly wht is it (a lead-acid/wet battery with a unique spiral lead plate structure and glass mat acid containment) and what it isn't (it can gas, and it has other idiosyncracies).Fred
That's a good battery. The trickle charger is what really keeps the lifespan at it's longest when you don't drive the car often. A regular car battery doesn't like to be discharged deeply, it destroys the cells. Deep cycle batteries are manufactured for those type of requirements.Originally posted by Injuneerthe AC/Delco Professional. I still have that one almost 7 years later, and its been very reliable, going months between starts of the car.
My car has had a die hard for 5 years without a problem. Awesome battery.97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
Delphi (note resemblance to "Delco") is a spinoff/selloff of a large number of GM parts divisions. While its no longer GM, its still the same people in the same plants. If you buy O2 sensors, injectors, etc, many of them now say "Delphi" on them. Delphi is, interestingly, close to bankruptcy.Fred
Always I've wondered the fact the same product will have different overcome with each different costumer.....if the quality is the same....supposedly....
It seems, like in human beings will respond in different way with the same medical treatment.....pardon me the comparison...of course there are several variables involved in each case....
These comments are regarding Fred's post about Optima batteries.....These batteries have an unusual look, indeed...but I'm pleased with the "performance".
Honest will be to say that the 3 OEM ACDelco batteries gave me in the last 8 years installed on my car a reliable performance too.
Regards
dochidalgo97 A4 Pontiac Firebird Trans am with $everal mod$
This is the link of the web site
http://www.optimabatteries.com/publi...ry_search.html
Regards
