Hello everyone... normally cars gets better as the weather gets warmer, not mine tho. Back in Febuarary i noticed a slight misfire in 4th gear around 1800 rpms.... That was it. As time went on the misfires started becoming more prodominate, and more often, throughout any gear. Now they are the worst in the low and the High RPMs, only when the car is warmed up. These problems get worse as the car gets hotter.... 210 and the miss makes the car barely driveable.
So i went and got some NGK TR5's and some MSD 8.5's. Changed out the plugs and wires, and put everything back together. Defintly makes the car pull harder, and smoother throughough all the RPM band. I pulled the car through WOT 3-4 times on a country road, and it seemed fine.
However, as the car got warmer, it started chuggin, and then started full out misfiring again. The car defintly runs alot better... but the problem is still there. Im thinkin OPTI. I have one, slightly used (2K) but it should do the trick. What needs to get pulled to do the opti?? I have a GM service manual, but can i get any pro's input with some tips and tricks. Thank you very much.
BTW. I drive a 1994 formula w/ 84kMI
