Found a brand new paxton blower on ebay but guy says will only work in a Impy w/ lt-1 didnt know if anybody knew if it would work in my 95 ta. one other ? does anybody know where would be a good place to get my car programmed around indy. took the car all the way to chicago and they did a @&!*%$ job. car doesnt idle out right wants to run 1100 to 1500 rpm sometimes and will idle out other times. car also is running really rich.
Much thanx
95 ta with ported and polished heads 2.00 1.55 valves, special ground cam from comp, 30# injectors, electric water pump, special built converter from coan transmission, and a crappy program from speed inc.
best et 860 in the 1/8th 2.40 60 foot
still to install
3.73 gears, moser axles, shift kit, subframe connectors.
Much thanx
still to install
