jumping out of fourth gear
  • jumping out of fourth gear
    Just started having a problem with this is the last few weeks. Unless I make extra sure to get the shifter into fourth gear, I am finding it jumping out of gear before I can continue on to 5th gear.
    Could this be a clutch issue? Have over 115,000 miles on the ragtop now with never any clutch work done on it.
    Or, could it be a tranny problem, perhaps in the synchronizers?
    Any help appreciated.
    2000 Z-28 Convertible, neutral leather interior and neutral top, hotchkis STB, SLP Bowtie Grill, WhisperLid, K&N, cold air induction
    If all other gears engage fine and the clutch is still good then its going to be the TRanny. The synchro's are messed up. Does it pop out under Load or normal driver? or both?
    Eddie
    2000 M6 Trans Am
    Tune+exhaust=344WHP
      most noticeable under load.
        I think its going to be your Transmission. The Syncro's are out of wack. A rebuild is called for. I had the same problem in my old Honda were I would Be Slamming in 3rd at the track and It would pop out and I would hit the Limiter. Scared the he!! out of me every time. I thought i was snapping axles.
        Eddie
        2000 M6 Trans Am
        Tune+exhaust=344WHP
          Thanks--kinda what I was thinking too, but really didn't want to think it
            Might be your shift fork. Mine did that in reverse only. I had a bent shift fork. I had it fixed it last year.
            Hercules
            2008 Sunburst Metallic HHR LT
