Alright. Well a while back I just had replaced the subs with some simply aftermarket Speakers. It was no where near as "Bassy" as stock. Well I got a component set And I went to put it in the front. Well I was reading The post "CirCut" made not to long ago and all the links he had, they are for Camaro's. I heard that the Firebird Monsoon system is different than the Camaro system. I realized that my car came with only one Factor Tweeter in the driver side door. The passanger side dorr did not come with a tweeter, simply the Mid 6.5" speaker, but there is the plug there for the tweeker. So this is what I did.
1. Replaced the 6.5" and hooked it up to the stock Harness for the mid-range.
2. Used the Tweeter harness and ran that to the Component set Cross-over then to the aftermarket tweeter. They sound good at low volume but if you put it up it starts to distort.
3. The other thing is I replaced the 2 speakers back in the cargo area, I dont know if this is causing to much load, or at what ohms those run.
4. I replaced the Sub's with the 6.5" Mid Range, but only hooked it up with 2 wires, since the stock speaker has 2 sets of wires. The other 2 wires are just there.
So at this point I dont know whats going on. Im getting just about no Bass at all. The speakers distort and its seriously starting to become a pain. Im already considering to go and buy a new Set of Stock Sub's b/c I have tried 3 different sets of Speakers and None "Bump" anywhere near as loud as the stock ones used too. (I replaced them b/c one blew)
One more question. Does anyone know at what Ohms Each speaker runs at?
Basically just these:
1. Mid-bass in doors
2. Tweeters in doors
3. Sub's in Side panel-Each set of wires
4. The 3"-4" speakers in the cargo area.
Thanks Guys
Thanks Guys
