I have another issue here as well. When I turn the key to the on position, the cooling fans turn on. Even after the car starts, the fans stay running even when 100% cold. I don't mind the extra power the cooling effects have but I also don't want to burn out the fans either. Anyone have any suggestions on what might be the problem? Thanks. By the way, I did change both fan relays. (89 formula 350)
too much cooling!!
On my car which is OBD1 like yours if there is a problem that causes the SES light to come on it will turn the fans on all the time. Is your check engine light on?2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
no the light isn't on and the car runs fine. I was thinking maybe the sending unit. Does anyone know where the sending unit is for this car?89 Firebird formula 350--95k on it, MSD ignition, full catback exhaust (flowmaster) 160 degree stat, custom chip from pcmforless.com, TPIS air filter, TPIS air foil, TPIS MAT relocation kit, built 700R4 with stage 2 shift kit and corvette servo.
Check for codes anyway. Easy enough to short the ALDL pins and flash and trouble codes on the SES light.Fred
If it's TPI or TBI, I do believe the sending unit for the fans is in the passenger side head towards the firewall. The sensor for the ECU is in the intake and the sensor for the gauge is in the driver side head towards the front.Originally posted by 89 formulano the light isn't on and the car runs fine. I was thinking maybe the sending unit. Does anyone know where the sending unit is for this car?'95 T/A Conv., Green, Tan Top
'00 T/A Silver
'86 Chevy RCSB 4WD (LS1
to go in)
