I have a coolant leak on my 94 Firebird with the 3.4L V6. I have tracked the leak down to the water pump, which will leak a good amount after driving on some days, or I can go for several days without any leaks at all.
I am pretty sure that the water pump is going, so I will change that. While I am digging in there, I plan on replacing the thermostat, serpentine belt, and intake manifold gasket.
Is there anything that you guys know that could help me out when I am doing this... and is there anything else that I should be servicing/replacing while I have everything apart? 115000 miles. Thanks.
