Cleaning the K&N Filter
  • Cleaning the K&N Filter
    I noticed the other day that I need to clean my K&N filter for the first time. It is the one that just slips into the normal position of a regular air filter not a modified one.
    http://www.knfilters.com/search/prod...x?Prod=33-2042
    So uhh this being my first time cleaning it what should I do in general and specifically the oil part of it?
    Thanks
    2002 Firehawk Sold
    I had the same question my first go round. I over oiled it and screwed up my MAF. When you spray the oil go along the ribs of the filter. You notice it soak into the fibers...you don't want it too dark red (like you saturated it), but just enough. You see spots of white (where you missed it or didn't spray enough) just hit it again ever so lightly.
    Use a lint free rag to wipe the excess off the edges and I pat the mesh to remove bubbles or build up.
      Its very simple, and make sure you dont use an air compressor to dry it. Let it air dry then Spray it from the side that the air is being introduced into the filter.
      Eddie
      2000 M6 Trans Am
      Tune+exhaust=344WHP
        http://www.knfilters.com/cleaning.htm
          Do not clean it too often. It is intended to go 25,000-50,000 miles between cleanings. Cleaning wears it out - about 20 times is the limit. A small amount of dirt does not hurt air flow, and may even make the filtering more efficient. Use only the K&N cleaning solution and filter oil.
            Ok stupid question (even though I am going to buy the cleaner kit):
            Why can't I put oil into a spray bottle and use it that way? What is so special about the K&N oil? Just Curious.
            2002 Firehawk Sold
              1 - It has the red dye in it, so you can see if you have coated the entire filter.
              2 - It was formulated by K&N to be the correct viscosity for the filter's design, and to be compatible with the materials of construction of the filter.
              Just follow the instructions. Don't try to pinch pennies. For something you only need to do every year or two, it isn't worth it.
                I went back to OEM paper filters, after noticing a jump in silicon after switching to a K&N filter. (I had my oil analyzed before and after switching to the K&N.) I'll see if I can find my reports and scan / post them.
                '99 A4 1.8T QMS Santorin
                (Hey, that's not an F-Body)
                  Interesting, I've heard pretty much nothing but good things about K&N. Would anyone like to share some downsides?
                  2002 Firehawk Sold
                    What tests did you have performed?
                    My DD
                    2015 Lexus GS350 FSport
                    My toy
                      air leaks
                      Many who use the stock size drop-ins report difficulty in getting it airtight, esp in motorcycles.
                      Mike, So. MD, USA
                      1998 Camaro 3800 5m, Borla, Whisperlid/K&N, ProForm shortshift, 17" chrome SS wheels, poly bushings
                        Standard oil analysis, sent in to Blackstone Laboratories. ($22.50 for each test)
                        http://www.blackstone-labs.com/standard_analysis.html
