I just got done installing my Pacesetter mids a few weeks ago and I have a few complaints that I just want to let everybody know about.
First thing that I noticed was that they sent me paper gaskets. I had already heard about this before, so I wasn't too disappointed. I used fel-pro gaskets for the headers. After running open around with just a y-pipe on... my paper gaskets at the 2.5" collectors were already leaking so I replaced them with mr. gasket collector gaskets. Also, the collectors come with self locking nuts. I just used normal nuts with locking washers and lock tight to make things quite a bit easier. Shorter bolts also made things a little easier on the passengers side collector.
Next thing was all the little welding specks that were all over the inside of the tubes and some on the outside. They could have at least knocked them off before putting the coating on.
The AIR and EGR hookups needed a ton of muscle to get all the way seated. I would recommend screwing something with the same size of threads in each one all the way before actually hooking up the AIR and EGR. Do this with the headers outside of the car also because like I said it takes lots of muscle. I couldn't even get the EGR hookup all the way seated because there was one of those little welding tits that i was talking about on the threads.
The steering linkage rubbed a little bit, but that wasn't really a big deal. Just had to adjust it a little bit and use a file on the corners.
They only send you 11 header bolts because they want you to use the old bolt that goes on the front of the passengers side header. This way you can mount the alternator bracket on the old bolt. I was unable to get the bracket to mount correctly because the headers use different bolt holes in the heads so the angle was off. Also with the reused 9/16 bolt i wasn't able to get my socket all the way down on it after it was so far in so I had to put 2 other nuts on top of it to be able to tighten it. I should have went to the hardware store and just gotten another 3/8 bolt, but now I'm afraid of breaking the seal if i take the 9/16 bolt out so I'll just let it be.
Spark plug clearance isn't as bad as I thought it would be with all the complaints that I have read about it.
I also want to advise people to just remove the dipstick right away because the slightest little bend in it could lead to a little bit of frustration when trying to get it back in.
With the dipstick out, everything was easy to uninstall and install. The clearance below the car is awesome. I definately noticed a little bit of a power gain. I'm running right along with my friends 2004 vortec supercharged mach 1. Last time I was able to do that was before he put the supercharger on it. I also want to say that after the car is warmed up it sounds great with the exhaust running through an ORY and loudmouth... not too much louder at idle but when you step on the gas its definately loud. Not to much different that running around with the exhaust cut off at the y-pipe.
1993 Formula - 99k
. Scares the heck outta those not suspecting the growl.
That point is where the exhaust gasses begin to cool, typically about 5-8 inches past the collector to primary union in a long tube header.
