My car's missing in 4th and 5th in the low and mid rpm's,high rpm's it doesnt,Plugs are changed,the car hesitates to give power,help please any one?????????????
missing in fourth
missing in fourth
2000 red vw jetta,86k stock
1995 firebird formula ws6 clone,crashed,frame damage ,soldTags: None
Very weird ,I capped my exhaust and the problem went away,the car also seems faster and is getting better mpg,(but sounds sissy)why would my cutout cause this problem,It's been uncapped for about 3 months2000 blue mustang gt vert 5spd,18''cobra rims,light bar,stalker bodykit,lowered 2 1/2'',roush side exhaust /with x pipe ,bbk cai,power products 75mm tb and plenum Pro 5.0 3:90 gears,Custom 91 octane SCT tune
This sounds stupid but does the cutout somehow bypass the O2 sensor? If it does that might casue the issue you mentioned. But I would think it would have happend right away and not 3 months down the road. Could be another issue with the cutout and the sensor, something in the wiring maybe.Tracy, 97 Formula, pretty much stock.
Originally posted by BrdWAtti2dThis sounds stupid but does the cutout somehow bypass the O2 sensor? If it does that might casue the issue you mentioned. But I would think it would have happend right away and not 3 months down the road. Could be another issue with the cutout and the sensor, something in the wiring maybe.2000 blue mustang gt vert 5spd,18''cobra rims,light bar,stalker bodykit,lowered 2 1/2'',roush side exhaust /with x pipe ,bbk cai,power products 75mm tb and plenum Pro 5.0 3:90 gears,Custom 91 octane SCT tune
If the cutout is past the cat then it's way past the O2 sensor. Might just be a coincidence with the cutout. I assume you capped the cutout after the car cooled off. Did you try it uncapped when it was cool?
The reason I ask is when my optispark started going it only seemed to act up at low rpm under load and when hot. Once I got to crusing speed the car ran fine, or at least fine enough so I couldn't notice. Not sure how the car's temp effects the opti but it did. On cold days the car would run fine, or let's say much better. Once it started going it was only a couple months and the car would barely run and a bad opti is a common performance issue. Have you replaced the water pump within the last year? All that water leaking is an opti killer. Are you getting engine codes? (check engine light on) If so, buy, borrow, steal an OBDII scan tool and check the codes.Tracy, 97 Formula, pretty much stock.
when the car is cold and ucapped it back fires,makes popping sounds till it's warm,but no I havent ,I usaully drive slow till it's warm2000 blue mustang gt vert 5spd,18''cobra rims,light bar,stalker bodykit,lowered 2 1/2'',roush side exhaust /with x pipe ,bbk cai,power products 75mm tb and plenum Pro 5.0 3:90 gears,Custom 91 octane SCT tune
Do you feel the backfires? Is it possible it's backfiring with the caps on and you just don't hear them because they are going through the stock exhaust and being muffled? I don't think the caps would effect the way the engine is performing or at least make it perform worse.Tracy, 97 Formula, pretty much stock.
well in the mourning it doesnt affect the performance it just pops when I shift gears,Conelite said thats normal and his car does it to,but in fourth there's no sound when it misses,Just hesition in power,But the cap on and now it's not happening ???2000 blue mustang gt vert 5spd,18''cobra rims,light bar,stalker bodykit,lowered 2 1/2'',roush side exhaust /with x pipe ,bbk cai,power products 75mm tb and plenum Pro 5.0 3:90 gears,Custom 91 octane SCT tune
You might also consider cleaning your MAF sensor. I recently did that on my ragtop, using MAF cleaner spray form Orielly's auto parts, and it's like driving a different car. I was having power loss problems and throwing all kinds of 02 sensor codes, and after I cleaned the MAF full power and no codes. Might take a look-a good $7 investment.2000 Z-28 Convertible, neutral leather interior and neutral top, hotchkis STB, SLP Bowtie Grill, WhisperLid, K&N, cold air induction
Originally posted by 00 Ragtop ZYou might also consider cleaning your MAF sensor. I recently did that on my ragtop, using MAF cleaner spray form Orielly's auto parts, and it's like driving a different car. I was having power loss problems and throwing all kinds of 02 sensor codes, and after I cleaned the MAF full power and no codes. Might take a look-a good $7 investment.2000 blue mustang gt vert 5spd,18''cobra rims,light bar,stalker bodykit,lowered 2 1/2'',roush side exhaust /with x pipe ,bbk cai,power products 75mm tb and plenum Pro 5.0 3:90 gears,Custom 91 octane SCT tune
A guy where I work has a 2003 Z06 and he was doing the same thing. It was caused by a dirty MAF. I think it may have been caused by a K&N filter to.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Originally posted by DHolmeswhere;s the maf and how do I clean it ,
that looks like my car,but isnt that were my holley throttle body is ,2000 blue mustang gt vert 5spd,18''cobra rims,light bar,stalker bodykit,lowered 2 1/2'',roush side exhaust /with x pipe ,bbk cai,power products 75mm tb and plenum Pro 5.0 3:90 gears,Custom 91 octane SCT tune
so where's the MAF right next to it on the right2000 blue mustang gt vert 5spd,18''cobra rims,light bar,stalker bodykit,lowered 2 1/2'',roush side exhaust /with x pipe ,bbk cai,power products 75mm tb and plenum Pro 5.0 3:90 gears,Custom 91 octane SCT tune
