Hi, I also posted this on my local forum, but haven't come up with an answer yet. Just wanted to try here too. I'm having a problem with my front passenger side turn signal. Here's the scenario: I've got a 96 Camaro.
At first it was an intermittent problem...front and back passenger side turn signals would sometimes work, sometimes not. I figured the turn signal switch was going bad. Then they quit altogether. A member told me to try and replace the turn signal flasher. That restored the rear , but not the front. So I now figured the switch was probably ok, since the rear was now working. The info I had showed that if the turn signal switch was bad, the whole side would be out. Now I've been told that the front bulb socket could be bad. I'm at that point now. I just went and bought a new socket and am about to put that in ($65 bucks for that damn thing!). Hopefully that restores the front turn signal. Anyone out there have similar issues, or have experienced this type of problem? The bulb is ok, and the hazards work fine too. I'd appreciate any and all info. Thanks.
