hypertech
  • hypertech
    Im still gettin pretty bad gas mpg,Is there anything that the previous owner could have set with the hypertech that could have caused,
    2000 red vw jetta,86k stock
    1995 firebird formula ws6 clone,crashed,frame damage ,sold
    Did he program it and left the Hypertech programming on the car? I doubt even with that it would make that much of a difference. I have made it evident that you like to mess around in ur car a lot. Try driving it and keep the rpms under 2000 rpms (except on the freeway) and see what happens. Im sure its just your way of driving.
    Eddie
    2000 M6 Trans Am
    Tune+exhaust=344WHP
      Yes it could be but I don't think it is. Has it every gotten good gas mileage? Is it throwing any codes? Is your air filter clean? Fuel filter clean? If your O2 sensors are bad, it can cause this problem also.
        plugs are changed,And the air filter clean,The rest I dont Know,the check engine light has never came on,I no the programming is on,there's no gov and rev limiter, Its always got bad mpg, better now because I capped the cut out,but still bad, a little over 80 miles, off 30 bucks@3.83 a gallon
          Nobody seems to have mentioned the fact that you're going to get crappy mileage in that car to start with. Have you actually calculated what kind of mileage you are getting? On the highway I'm lucky to get 24mpg, prolly closer to 19 or less, in town, whew, it's dismal. Plus when gas prices go up your mileage always seems to go down, but I'm sure that's just a matter of perception.
          Tracy, 97 Formula, pretty much stock.
            Your averaging 10.2Miles/Gallon. Thats horrible. I get 25+ on highway and 15mph in city driving like an idiot. You have something seriously wrong or you have a heavy foot.
            Eddie
            2000 M6 Trans Am
            Tune+exhaust=344WHP
              well I was heavy on the gas for a couple of stang kill's,but rather then that Ive been pretty light
                My 95Z A4 get 18-19 city/hwy and 23 hwy @ 70-75 mph. This is with a mild cam and not lead footing it around. If I use the car for work as an appraiser where there is a lot of sitting and idleing, it drops way off to about 13-14. So if you sit and idle a lot in traffic this could be the trouble.
                  I suggest you to scan the PCM history DTCs, maybe there is one.
                  Time to replace your 02 sensors even there are not DTCs about malfunction.
                  Clean your MAF sensor, seek for vaccum leaks...
                  Good Luck
                  dochidalgo
                    im gettin 13 in my truck around town and like 18-20 on the highway but thats my truck. my old 88 t/a when i was heavy on the foot(drag racing) it would get bout 9mpg but highway was around 25mpg when it was just a cruise but my car needed to be tuned bad, it was running way to rich
