I'm trying to pull the crank pully off an LT1 to change the front seals. What's the best way to keep the engine from turning over while I'm trying to loosen the pully bolts? It's probably a simple solution that I'm overlooking.
Crank Pully
Using an air impact gun makes it a relatively easy task to get the bolt out, without hold the crank still. Without an impact gun, if its a manual tranny, put it in gear, if its an automatic, you have to jam something into the teeth on the flex-plate.Fred
Yea I got those by putting a breaker bar on the center hub bolt. Sort of a contortion act but I got em. Now I'm up against the same thing with the center hub bolt. No air tools unfortunately, that would be way too easy. So, I guess that means pulling the starter to jam something into the flex plate teeth unless somebody has another way of getting at this.Tracy, 97 Formula, pretty much stock.
