Yes, I've made some research work and I found excellent information about this issue in this excellent and reliable forum.
Now the first facts:
1) None DTCs with my scanner.
2) Two months ago the PCM was reprogrammed with a real time tunner man sat in the passenger seat....I have understood the pulse widths was changed among others parameters...Since then, the car pulls firmest and strongest than Fast Chip programm...But, I´ve noticed a little less fuel economy and water+carbon mix from the exhaust tips.
3) Fuel filter replaced about two months ago. However it could be partially clogged, but the car runs fine even at WOT...The racetronix injectors are one and a half year new.
4) No fuel odors from the fuel pressure regulator when I disconnected the vaccum line from it....
5) Cold engine Ignition On, engine Off: IAT sensor read 88°F/ECT sensor read 82°F.....That's my concern now....The temp difference between these two sensors must be 5°F maximum, isn't it?....then the ECT sensor is faulty? Even there is not DTCs P1114-1115?..
6) I'm in the process to get a fuel pressure gauge in order to get the readings from the fuel pump check valve....I hope the device is well yet ( 65k mi).
Thanks for read my post and mostly for your imput about this issue.
Dochidalgo
Dochidalgo
