today i had a problem with my car, it was idling fine, driving fine, then it did this jerky motion and stalled out, i pulled over and tried to start it, but it would only turn over. I checked the voltage of my batt, it was fine, i check to see if the generater was plugged in and it was. I unplugged the neg cable from the batt for a minute of two, plugged it back in and it started up fine. I let it idle for like a minute and a half, then i started driving. about a mile down the road it did the jerky motion again and i pullede over again. i did the same thing with the batt and just drove it home. it drove fine, and had no hic-ups at all. I noticed the Check engine light had come on. it popped out trouble code P1371 which = Ignition Control (IC) Module 4x Reference too few pulses. That is as good as greek to me. but i'm guessing, check the cap n rotor, bad opti? or could it be a fuel filter possibly? I'm stuck! ANY help is help. Thank you in advance!!
o btw, i changed the plugs myself (5 hour nightmare) 2 weeks ago and double checked the wire boots 2x today.
