What all do i need to do to change the timing gasket and front seals?
Removal Of the Timing cover
just get the kit. it's 18 at advance auto. Comes with the 3 seals for the timing cover and the optispark seals.
Just be careful with the top small seal that goes over the water pump gear. Very easy to destroy.97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
They all get installed dry.Originally posted by ToplessFormulaBe sure to read the directions that come with the gaskets/seals.
If I remember correctly the top waterpump drive seal MUST be installed dry.97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
The front of the oil pan needs to be lowered to correctly remove/install the timing cover.Rob B 95Z A4 Tech Page (Part numbers / locations, how to's, schematics, DTC's...) Home Page - shbox.com
so heres how is goes right?
1. remove water pump, fans, opti, hoses, and c/s pulley
-i got the pulley off, how do i get the hub off?
2. drain oil(?) then lower oil pan,
3. remove all bolts holding front cover on,
4. remove all seals from cover, then install new cover gasket and seals.
5. reinstall bolts for front cover, and then raise the oil pan back up. i'll probably need a new pan gasket too huh?
-Ryan-
Look on my Tech Page in the How To's section for cam removal and skip down to the "~Disassembling the front of the engine~" part. It will take you through it. You won't need a pan gasket if you are careful and dont tear it. It will have to be carefully pried out of the timing cover.Rob B 95Z A4 Tech Page (Part numbers / locations, how to's, schematics, DTC's...) Home Page - shbox.com
I didn't have to drain my oil to lower the pan. Just loosen the bolts a little bit to where it drops enough not to tear the gasket.
You need to pull the hub off the same way you pulled the pulley off. A claw puller didn't work for me.
Use a crow foot puller.
Remove the 5/8" bolt thats in the hub.
Take a bolt that is thinner than the factory hub bolt, but a few inches longer, and stick it in until it stops inside the crank.
Take some 3" bolts (maybe 2.5") that are smaller than the holes in the hub, so they can go thru the hub, put it thru the crows foot, then thru the hub. Put a nut on the back of each one, and crank it. It'll come off easily.97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
You must get different seals then.Originally posted by raroZ28They all get installed dry.
I know that the crank seal is just a conventional oil seal when I purchased mine.
Don't install the waterpump seal in the cover and then install the cover. Install the cover first, then install the waterpump seal. That will help avoid damaging it.
