hey guys, lookin for some knowledge. 95 camaro has excessive wheel noise, and steering wheel shakes during braking. new ceramic pads and slotted rotors only 3k miles ago, and all signs lead to bad wheel bearings. can i replace the bearings, or do i have to replace the whole hub assembly??
95 camaro wheel bearings...
You can get it off...just needs a lot of effort. If you want to do it the cheap way you basically need a cheater bar...
Use a socket wrench, get a 6 inch extender with a spark plug socket and use that as an entention (your cheater bar) so you can get more leverage.
Works...just be sure your car is stable.
What he said plus don't forget to unplug the ABS sensor from the back side of the hub assembly before you pry on it.Originally posted by ChristopherrrYou can get it off...just needs a lot of effort. If you want to do it the cheap way you basically need a cheater bar...
95 Z28, A4, 3.23's and some other stuff....
