If the Clutch master cylinder is not working properly, Can it cause the clutch to not disengage completely? I got the same problem I had before. I would have my clutch slip. So I changed the clutch. Then a little later it started to slip under normal driving. So i replaced the Slave cylinder, and it went away and now it came back. The weird thing is that once in a while the clutch engages completely and does not slip at all. Can It be the Master cylinder?
I need to know as soon as possible b/c Its dyno days tomorrow, so I can Switch out the Master tonight. What do you guys think?
