I am looking at some wheels in a 18X10.5 for the rear and was wondering if 315/30/18 would fit back there...the main thing i was concerned about is the heigth of the sidewall...anyone got any experience running these size tires on a 4th gen?
Tire question
Originally posted by ws6drbobI am looking at some wheels in a 18X10.5 for the rear and was wondering if 315/30/18 would fit back there...the main thing i was concerned about is the heigth of the sidewall...anyone got any experience running these size tires on a 4th gen?Eddie
2000 M6 Trans Am
Tune+exhaust=344WHP
Acceptable wheel width is determined by the tire manufacturer. Most manufacturers accept a wheel width of 10.5" - 11.5" for a 315/30-18. The BFG 315/30-18 Drag Radial requires at least an 11.0" wide wheel, for example.
That tire will be slightly smaller in outside diameter than your stock tires, but the speedo error will be less than 1%. The fact that the diameter of the tire is close to stock should not cause any issues with rubbing. To a large extent, it will depend on the actual section width of the specific tire you choose - not all "315" tires are actually 315mm (12.40") wide. Some are wider, most are narrower. Since you are on the narrow side of the acceptable wheel width, it will tend to make the actual tire section width smaller than the published number, which is usually done on an 11.0" wheel.
Whether the tires will "fit back there" depends on the offset/backspace of the 18x10.5" wheel. Do you know what the offset of the wheel is?Fred
Im dont know for sure but i believe it is available in a +56mm which is what i was told is a good offset and will put the edge of the tire right to the outside of the fender without sticking out. I am getting them from a friend who is a wholesale dealer and i'm to hear from him on the exact specs of the wheel i am looking at, but he said he has sold the same rim to guys with 4th gens before and they looked great.1997 6-spd WS6 Trans Am
