I installed a new distributor, plug wires, distributor harness and still no go. I checked to see if it was giving me spark, and it was not. the engine turns over, but wont start. what could the problem be? coil?
No start, no spark
Check the harness going to the ICM for proper voltage and signal. It could be the ICM (Ignition Control Module). Rob (Shoebox) has the procedure here...
http://shbox.com/1/4th_gen_tech2.html#opti_testSteve
Mods
87 GN - its just a 6...
Mods
93 Z28 - slightly tweaked
Mods
Check the Opti harness connectors, both ends (at the Opti and on the passenger side of the intake manifold) for damaged pins.
Can we assume you changed all those parts because it wouldn't start? If so, did you have any kind of diagnostics done, have it scanned for codes, etc.?Fred
yesr i bought a new opti harness. but i just found that it wasn't plugged in all the way, it felt like something was holding it up, but there was nothing bent or messed up so i'm thinking i bought and installed a faulty opti. because the harness plugs in fine to the old opti, and it wont plug in at all to the new one. and yes, i bought the right one, Vented Opti-Spark II. but i went cheapo and went with the Jegs brand. So they're gonna refund me in full and i'm going to buy another NEW one. Back to taking off the water pump, fans, c/s pulley, belt, opti and intake shnorkel-bob for the 3RD TIME!!!! damn.
-Ryan-
If you have the correct vented Opti harness, and it wouldn't plug into the Opti, was it a "faulty Opti", or did they send you an unvented Opti? Did the Opti correctly engage the dowel pin on the cam?Fred
well i know they sent me the right one because there were two hose fittings for the vacuum and intake on the bottom of the opti, and the opti fit right with the dist. drive.
the car would start when i held the harness in place with a screwdriver. so either the distributor was faulty at the harness connection. now i just have to wait for payday so i can buy another distrubutor.-Ryan-
