Too many hydrocarbons. What could cause this? The mechanic said the humidity contributes to hydrocarbon emission. The only thing I can think of is that can of BG fuel additive I put in a few weeks back. How do I get these numbers down?
Failed emissions
Failed emissions
SOLD- Kinda miss it
SOLD- Good riddance!
2006 Ford Fusion: 2.3, 5 speed, could run 15lbs of boost with a 150 shot and it'd still be slowTags: None
What were the actual numbers, vs. limits, for HC, CO and NOx?
High HC and normal CO might indicate a leaking injectors. High HC and high CO might indicate running rich. High on all three might mean a weak catalytic converter.Fred
Originally posted by InjuneerWhat were the actual numbers, vs. limits, for HC, CO and NOx?
*EDIT* My CO count was normal.Red 95 Trans Am: M6, Moroso CAI, Magnaflow, Spohn sway bars, back to life as of 2/15/10!!!
SOLD- Kinda miss it
Which injectors should I go with? Ford SVO's? What flow rate?Red 95 Trans Am: M6, Moroso CAI, Magnaflow, Spohn sway bars, back to life as of 2/15/10!!!
SOLD- Kinda miss it
Pull the fuel rails up, turn the key on to pressure the fuel system (do not attempt to start the engine), and look for drips coming out of the injectors.Fred
Thanks Fred. The mechanic said I had a bad O2 sensor. It passed today.
Quick question, why can't you pass inspection if you have long tubes with cats? I've heard it's because you have to relocate the position of the cat, but does that do something with emissions produced? The mechanic told me that as long as the catalytic converter is present (and not gutted), he'd pass it.Red 95 Trans Am: M6, Moroso CAI, Magnaflow, Spohn sway bars, back to life as of 2/15/10!!!
SOLD- Kinda miss it
Legally you can not touch the converter unless it is bad. Then you have to replace it with what came on it. You can not relocate it.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
I've got two places that will pass me through. I think long tubes may be in my futureRed 95 Trans Am: M6, Moroso CAI, Magnaflow, Spohn sway bars, back to life as of 2/15/10!!!
SOLD- Kinda miss it
Originally posted by Jeff 95 Z28Legally you can not touch the converter unless it is bad. Then you have to replace it with what came on it. You can not relocate it.Dave
Independent AMSOIL Dealer
94 Z28 M6 - exhaust, K&N drop in, and lots of plans...
DD 98 Ram 2500 CTD (might be faster than my Z!)
Originally posted by darkhorsecustomsDoes that mean that you can't legally put a high flow cat on, unless something is wrong with your original one??2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Originally posted by Jeff 95 Z28No. You can not put a high flow cat on any car that came with a converter. Legally you can only put a high flow cat on a car that did not come with a converter at all. If a converter is bad you can only replace it with what the factory put on it. I am not making this up and it is ridiculous I know and I certainly don't agree with it but that is what I have read.
Unless you're saying that the high flow cat will cause my emissions to increase beyond legal levels, or I'm misunderstanding you with something elseRed 95 Trans Am: M6, Moroso CAI, Magnaflow, Spohn sway bars, back to life as of 2/15/10!!!
SOLD- Kinda miss it
Originally posted by NightrageI'm not disagreeing with you. These guys simply told me that all they do is look to make sure all of the equipment is present, then emissions test it. He said that he'll pass me if I have the stuff, whether or not it's in the stock location.
You could put catalytic converter on your car that worked 10 times better than the stock one and it would be illegal. The law just states that you can not alter the emission systems in any way from the way it left the factory. I think it is a stupid law. To me you should be allowed to alter it as long as you don't make the emissions go up.
Most people will pass you if they see a converter because they don't know what was stock.
My 85 Mustang GT had a single converter from the factory. I put true duals with Thrush high flow converters on it and the emissions got better. I never had a problem getting an emissions inspection.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
