FOr anyone whoos done one or knows exactly what it takes, What extra parts should i have besides the main things like the cam itself, springs (the whole kit) pushrods, timing chain and in my case oil pump. Is there any gaskets i should have to buy, or that im going to probably wanto replace? Any oil of any sort?... let me know.
Cam install odds&ends
1969 z28 - 9.957 @ 133.92 1.425 60 foot.Tags: None
If your not going to replace/remove the intake manifold then your going to have to use the magnet trick to keep the Lifters up when removing the cam. Your going to need some assembly lube as well as all the gaskets. I recommend you looking for an LS6 intake manifold. The springs? Your going to replace just the springs or the rockers and retainers and keepers? Its not the easiest job if your going to do it yourself. I'd say about a 7-8 on a scale of 1-10 (10 being the hardest).Eddie
2000 M6 Trans Am
Tune+exhaust=344WHP
