Something weird happened.
  • Something weird happened.
    Ok, today i was taking off out onto the highway and a car was coming so i take off a little harder than usual. I get up to 3k rpms, and then i let off the gas a tiny bit for some reason. then i go to push the pedal and all of a sudden there was like a clunk or something. and my rpms only went up to like 1700k. it was really strange. felt like it had to do with the trans. any knowledge on what this may be?
    1994 Pontiac Trans Am A4 Pacesetter Ceramic Coated Longtubes,3" ORY,Dual 3" Cutouts,No Cat,!AIR,!EGR,K&N CAI,Flowmaster Exhaust,Mad Z28 Tune,Spohn Subframe Connectors,Eibach Sportline Lowering Springs,KYB Shocks,17x9.5 Chrome ZO6 Rims,5% Tint
    You might want to check your tranny mount...
    2002 V6 Firebird (wifes)
    2013 GMC Sierra (mine)
    2011 Cadillac CTS4 (wifes)
      Ok so you dont think it has anything to do with the trans itself? cuz that wouldnt be good news. how do i check the trans mount?
        Specifically, the rear mount where the trans rests on the crossmember. When they deteriorate, and they all do...... the trans is free to move around. Dump the clutch from 3000 rpm and you can watch the trans will rise off the crossmember and bang against the driveshaft tunnel. Replace it soon before anything else gets banged up.
          Is it a simple task to put in a new mount? I'm pretty sure i could take it to the auto shop at at my old school. I could put my car on the lift and then basically i'd need to support the tranny, and then unbolt the crossmember and swap out the old and put in the new mount right?? shouldnt be too big of a hastle
            Yea that's pretty much it. It's a 10 minute job once you get the car off the ground. And yea that clunk will scare the bajesus out of you.
            Tracy, 97 Formula, pretty much stock.
              make sure to replace it with an aftermarket polyurethane mount.
              87 GTA: it's winter time, all tore apart
                Haha yeaa when it happend i thought my trans was gonna fall off the car. I found a poly mount on spohn.net for like $25 so i'm gonna go ahead and order it.should be no biggy.
                  Just baby it until you get it in and you'll be good to go.
                    So that means no gettin on it?? i rarely do, but me and my girlfriend are driving it up to Reno tommorow for Hot August Nights! i thought i'd have a lil fun up there
                      Well, don't tell anyone, but I drove mine for a little while with the mount broken and ummm yea I would occassionally get on it and nothing bad happend other than the $%#@# clunk. Honestly I figured it would be a three day repair just like everything else so I put it off, had I known it was so easy I'd have done it right away. On the other hand, your going to reno man, that's not enough?!?!
                      Having said that I'll add the usual disclamer......
                      Don't try this at home...these are professional drivers on a closed course.
                        hahahahha well i can deal with the clunks. besides my exhaust will probably drown it out so its all good. Well its a 3 hour drive from here, so i thought baby it on the way up and when i get there i will have some fun.
                          just remembr when it clucks its moving up, so the motor is moving down(in theory) and there for u could break a engine mount or destroy the driveshaft. unlikely but it could happen. i broke my tranny moutn adn 3rd gear at a magazine deal at englishtwo nj and drove 150miles home
                            Finaly a question i can answer!!! i had the same problem to. the thump scared the crap outa me. considering i just fixed a few major problems i though oh god now what. i thought i was screwed.. later i lifted the car and saw the bolt missing from the trans mount .. anyway just lift the car, while its up put another jack on the back of the trany and lift the tranny as far as it will go up as this will raise the trans up away from the cross member. when i did it i didnt need to remove the cross mem.(the spare tire jack works great!) . That should give you enought room to replace the mount. if it doest then just take the cross member off too. VERY easy fix. Make sure you use a lock washer on that mount, i didnt use one and the bolt loosened and fell off. the trans will vibrate a lot so make sure its tight. Good Luck
                            1987 Formula Firebird
                            GM crate 350 5.7L carburated
                            MSD, Edlebrock intake and carb, Dynomax headers
                              Uhhhhhh well thanks for all the tips. Even though i didnt baby my car yesterday, raced a 2000 and something 'Vette convertible from like a 65 mph roll. hahaha yeaaa i'm bad. but i didnt hear the clunk when i floored it. Maybe it's more from a dead stop when it happens the most.
